Wiz's avatar
Wiz
Toad turn signal lights don't blink when tail lights are on.
I've have a 2000 Coachmen Class C motor home on a Ford E-450 cutaway chassis. I tow a 2004 Honda CRV behind it with a Blue OX towbar. I have a problem with the extra lights on the toad. If the coach's tail lights are on, the turn signal lights barely blink, the just stay bright with a very slight dimming each cycle instead of turning off and on. I have the same problem whether I use magnetic tow lights or additional lights I wired into the CRV tail lights. If the running lights/tail lights are off, the lights blink correctly. I've replaced the blinker relay with a heavy duty one with no difference. Looking for ideas how to isolate and fix the problem.
Thanks!
  • Thanks! I will check the ground wire today. Since the chassis is the ground, doesn't it just need a good connection to the frame?
  • 99% of the time problems like this are caused by weak or bad ground.
  • I would also check the ground wire. You might try some jumper cables first, and see if that makes it work right.
    Fred.
  • Sounds like the ground wire return is screaming for attention. Turn signal elements consume 3 times the power of tail lights.
    Hook everything up. Then use a volt meter. Set to Volts. Connect the positive lead to the tow vehicle the negative to the toad. What do you see?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
