LaunchnRetrieve's avatar
Jan 18, 2015
Trailer Jack
More Spring Cleaning
Noticed my trailer jack is hard to crank this time.
Figure 1 of two things. The last 60 mph storm rocked it enough to bend it. Or it just needs lubrication. Let's run with the idea of lubrication.
http://tinyurl.com/o4o5229 Best image I can find, but figure you'll probably recognize the style if you've had one.
So how do I lube this and with what? I don't want to just start taking thing apart if it's a simple lube point that I'm recognizing.
  • 77charger wrote:
    Mine got hard to crank and it had grease in it.While jacking up the trailer i had an eery feeling about it so moved my legs slightly wider the next crank it fell down gears had stripped.
    Well, that's at least a reminder not to be under things that can fall even when a fall isn't expected.
  • Mine got hard to crank and it had grease in it.While jacking up the trailer i had an eery feeling about it so moved my legs slightly wider the next crank it fell down gears had stripped.
  • Old-Biscuit wrote:
    Remove top cap...then you can disassemble further.
    Remove handle/gears/inner tube OR just grease it from top
    Becoming very indebted to you, OB. Thank you.
  • Remove top cap...then you can disassemble further.
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
