Bobbo
Aug 29, 2016Explorer II
sch911 wrote:
The TT light bulbs have two filaments. One for turn/stop, and one for running lights. Your running light is not getting power or ground.
Since both filaments use the same ground, it shouldn't be the problem. Follow the hot wire back and you will find the problem. (Assuming the bulb filament is not burned out.)
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
