artman
Jan 02, 2017Explorer
Trojan HydroLink installation and winter
If you have 4 batteries 2 upper and 2 lower do you need two systems or just 1 ?
What do you do for winter ?
http://www.trojanbattery.com/pdf/TRJN0149_HLClpTubingMan.pdf
Says "Water supplies must be drained and stored in an empty state if they will be exposed to freezing
temperatures. Failure to do so can cause permanent damage to the watering supply."
also says "The HydroLink vent is not intended to be removed once installed."
I ASSume this means remove the snake tubing from the top and put the vent port plug that came in the vent manifold back in.
Thanks
Thanks
