mobeewan
Jul 25, 2019Explorer
As long as you can still open and close your cabinet doors you might consider getting a piece of three-quarter inch marine plywood and using it to cover the entire floor of the camper with the exception of the area to access the wire, pump and tubing. Then you could cover the new plywood with a single piece of new vinyl flooring with trim molding around the edges. You're going to need new vinyl flooring anyway. Just make sure to use short screws over the water tank when screwing the new plywood to the old plywood that you haven't removed.
