RayJay3
Oct 06, 2015Explorer
Truck pulls to side when braking and pulling my trailer
Earlier this year I changed from a 26' 5th wheel to a 24' regular trailer. When towing the RV, I apply the brakes and the truck wants to pull to the left and sometimes to the right. When going slow the steering wheel turns very hard to the left. This happens about 95% of the time when towing and braking The truck does not pull to either side when not towing.
The RV dealer has adjusted the RV brakes 3 times and the problem is still there. They supposedly towed the trailer to test braking and it did not pull to either side.
I pulled a 5th wheel earlier this year without any issues. The dealer says that they have done all they can do and it must be something wrong with the truck - particularly with ABS system.
The truck is a 2011 GMC Sierra Denali 2500HD crew cab with 6 bed.
What could be causing this problem with the truck?
I have read a lot of articles on this type of problem but all point to the brake system on the RV. I will tow a friend's RV and also have him tow my RV to see if the problem follows the RV or truck.
