Jim_in_OKC
Feb 10, 2016Explorer II
I have a 2010 Sequoia, and I think the cab layout is the same as the Tundra. I've made a bracket that sits in the recess at the front of the console and holds my brake controller. The attached photo shows it in place. The white material on the right is simply foam wrapped around the piece that sits in the recess to keep it in place without the need for screws. That makes it easy to remove (though I actually leave it in place most of the time). Hope this helps you with ideas for your own solution.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
