rburke's avatar
rburke
Two Outlets in GFCI path not working
I have 2 outlets controlled by the GFCI that are not working and 2 that are. In the kitchen. there are 2 protected outlets, one works and the other doesn't and the outside receptacle does not work.
The GFCI receptacle is in the bathroom, seems to test and reset properly - but when reset still have those 2 outlets out.
Was thinking about replacing the GFCI but I am not sure, or maybe the non-functioning outlets.
Any ideas? I may need to call an electrician in on this one but thought I would try here first. Thank you!
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
