โMay-14-2013 11:15 AM
Mike Shepherd (VE7PRT)
Pulling Power:
2008 Dodge Ram 3500 Quad Cab 4x4 6.7L CTD, 68rfe, Brakesmart, Edge Insight CTS
Sleeping Space:
2007 Rockwood Cargo-cum-Camper Trailer
โJul-10-2013 10:55 AM
Wayne Dohnal wrote:
Watts don't mean beans, it's all about VA which is what the eu2000i is rated in. When running from the eu2000i and supplying 65 DC amps, my PD9160A draws 1386 VA (actual measured values). Using a straight proportion supplying 80 DC amps would require 1706 VA. The 1.1 amp fridge adds another 132 VA for 1838 VA. Guess it's possible in generator-friendly conditions, but you've got to be right on the edge. My eu2000i maxes out at around 1,900 VA at low altitudes and reasonable temperatures. I've seen several other users report the same thing.
Pulling Power:
Sleeping Space:
โJun-30-2013 02:36 PM
โJun-30-2013 02:21 PM
โJun-30-2013 01:51 PM
โJun-30-2013 11:51 AM
BFL13 wrote:
Love Rathtrevor, especially during the herring run. However, it looks like the fridge was the culprit and you should have been on LP for fridge. Fisherguy runs his 9280 with an H2000, but that maxes it out AFAIK.
Pulling Power:
Sleeping Space:
โJun-30-2013 11:45 AM
Canadian Rainbirds wrote:
There's your problem Mike! It was plugged up with excess electrons. Running the ham gear cleared them out. :B
Art, VE7FED, VA7RV
Pulling Power:
Sleeping Space:
โJun-30-2013 11:42 AM
mikestock wrote:
You know that a regular RV fridge doesn't have a compressor. If there is a heavy starting load you must be talking about a home style fridge.
Pulling Power:
Sleeping Space:
โJun-13-2013 06:41 PM
โJun-13-2013 06:12 PM
ve7prt wrote:
UPDATE!!!!!
So, I used Lil Red On Sunday (June 09th) as the power supply for my portable radio station. I was Net Control for the 2013 Edge-To-Edge Marathon held that day (race goes from Tofino to Ucluelet). The total load on the genny was 2 laptop power bricks, 1 LCD monitor, 1 MobiCool (powered cooler) power brick, and 1 intelligent 30Amp battery charger. Lil Red ran from just after 0700hrs to about 1530hrs without refueling (I had fueled her up prior to departing for my station's location). I had no issues at all with the Eco-Throttle - Lil Red held a constant RPM the whole day.
So, I don't know what the issue was originally with Lil Red constantly changing RPMs on the Eco-Throttle, but whatever it was, it appears to have cleared itself. I still think it was water getting somewhere it shouldn't be.
Cheers to all!!
Mike
โJun-13-2013 05:49 PM
โJun-13-2013 11:42 AM
Pulling Power:
Sleeping Space:
โJun-02-2013 04:42 PM
โJun-01-2013 05:54 PM
renoman69 wrote:
Was this a 2000i genny? Some on here will tell you it will never run a 75amp+ converter but we know they are wrong.
Pulling Power:
Sleeping Space:
โMay-24-2013 06:34 AM
