Mike_Schriber
Aug 03, 2015Explorer
Unusual pinging issue (2005 Ford three valve V10)
I've been having a persistent and unusual pinging issue that just got worse on a recent trip.
Typically, it would ping totally at random at or near full throttle, usually when going up a big hill. When this happened, all I had to do was back off the throttle and then reapply it for the pinging to go away.
On my last trip, it started pinging (again, at or near full throttle going up hills) and this time it wouldn't go away. It was warm at the time (~95 degrees) and I was between 2,000' and 4,000' elevation (usually the elevation makes no difference). I had to drive up large hills at reduced speed for quite a while. Then, all of the sudden, it went away and everything worked normally.
Any ideas on where to start with this? The computer isn't throwing any codes.
Thanks!
Thanks!
