โMay-10-2016 02:04 PM
โMay-11-2016 04:55 PM
RoyB wrote:
You are making this very hard.... All that needs to be done is remove the components in the bottom of your....
โMay-11-2016 06:55 AM
โMay-10-2016 07:56 PM
โMay-10-2016 06:59 PM
Almot wrote:+1 on all this.
#1: You don't want to be without converter. Upgrade it, so that it wouldn't boil batteries and would output 13-14V without battery.
#2: Converter already IS a multistage charger. They are 3-stage. Illiterate Amazon descriptions might talk about 4-stage though.
#3: Solar won't have any adverse effect on other charging sources, install it if you want to minimize generator time and charge battery fuller.
#4: You don't want to ditch the alternator. There are ways to isolate the charging of starter and coach battery, if you need to.
โMay-10-2016 04:50 PM
โMay-10-2016 04:42 PM
โMay-10-2016 04:39 PM
2oldman wrote:
Is there an inverter in this mix somewhere? Do you dry camp?
If you're on shore with a charger you really don't need to have solar working with it.
DrewE wrote:
I think you may be a little confused about how things are wired currently. The 120V and 12V systems are isolated from each other, except in that the converter is a 120V load and โฆ.
โMay-10-2016 04:06 PM
โMay-10-2016 03:05 PM
โMay-10-2016 02:48 PM
