- gboppExplorer
mr_andyj wrote:
curious what that is even...
This is the most vague post I have ever seen
If you have/had a rig with AutoPark, the OP's post is crystal clear and self explanatory. - GjacExplorer III
base1957 wrote:
Which switch are you referring to? What is it supposed to fix and how much does it cost?
yes dutch.... just wondering if anyone has use the upgraded version of this switch that ultra RTV sells.... - base1957Exploreryes dutch.... just wondering if anyone has use the upgraded version of this switch that ultra RTV sells....
- Dutch_12078Explorer II
The "rotten green switch" refers to a switch used on the P32 chassis auto-park system that's prone to failure at the most inopportune times.
15961566 - Switch Asm - Park Brake Pump ( AKA Rotten Green Switch or RGS) - mr_andyjExplorercurious what that is even...
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
