Huntindog
Oct 01, 2015Explorer
In a bind does not mean contact... It would take contact to leave marks. Do the test I described with out the shocks in place. If you do NOT have the necessary clearance, then the shocks will be put in a bind. Nothing wrong with with the Northwood pic, except it doesn't really show how much clearance there is.... And as I noted before, welding to the top web of the frame is a great way to set the TT on fire. To do this the box needs to be lifted off of the frame... Think about what is intailed in doing this to an already built TT... It would make moving a gas line seem real easy... (it is, I've done it)
