Victron/lifeblue system 99% functional except
Mako_Kupo
Hey everyone, been a while! I have my solar system installed, it is all Victron (5000w 12v quattro inverter)equipment with LiFeBlue(3x 200ah lithium)batteries. That means I am using the lynx bus bar and shunt to connect everything to the batteries safely. Most of the system works, I can put power in the batteries and use that power on 110v, canโ€™t test out the 12 V yet but that shouldnโ€™t be a problem. All of the information on the system is viewed through the color control screen made by Victron, and everything appears to be working properly .
However, I have gone through two lynx shunts. this is a fuse block that goes between the two busbars, it holds an 800 amp CNN fuse. The fuse has not blown, but both times I installed a new shunt it worked for a split second and then sparked, never to show a sign of life again . The shunt limits current to the batteries, and also prevents overcharge and over discharge. Its a โ€˜smartโ€™ bus bar, and the spark appeared to happen on the small computer board next to the fuse in the shunt.
Even with the shunt not working, I can still use the system normally but i wont until its 100%. I can put up pictures when I get home in about an hour or two, but any ideas or thoughts will be helpful. Thank you all!
31 REPLIES 31
2oldman
CA Traveler wrote:
Those three boxes are adding extra connections which are not desirable in a 12V high current setup.
thanks. Yeah, high performance systems should not be 12v.
CA_Traveler
The shunt and other items are inside the Lynx Shunt. The shunt is on the negative buss, fuse on the positive buss and the control board in between.
2014 Grand Cherokee Overland
Bob
2oldman
jharrell wrote:
Make sure the temp monitor is on the right battery post, the only diagram I can find for the lynx shunt shows it on the positive post (from am solar):
I'm having a hard time finding a shunt in that diagram. I thought they were supposed to go on the negative side.
CA_Traveler
Look for companies that service/upgrade boats AND have experience with your equipment. There are some in the NE.
He justified the 12V choice. While there is no information on battery space - 3 12V is parallel is likely more power than 2 12V in series.
Bob
jharrell
https://static1.squarespace.com/static/562bc73de4b0908330f67ee0/t/5bcf960c08522908f02ec2b0/154033102...
My Magnum temp monitor didn't like being on the positive post but thankfully did no damage, the manual showed it being on the negative.
One thing I don't like about Victron is their documentation, Magnum has them beat here, can even find a manual to the Lynx shunt from Victron.
2016 Winnebago Vista 31be - Blue Ox Rear Track Bar - Centramatic Wheel balancers
2016 Jeep Wrangler Unlimited Rubicon Toad - Readybrute Elite Towbar
Mako_Kupo
2oldman wrote:
Mako Kupo wrote:
this post is not about why i chose 12v over 24v, thank you though!
Ok, but you just explained to Gordon why you chose 12v.
Judging by your answer about solar I'm not sure you understand the concept of wiring things in series.
i know how to wire in series. it is redundant now. i heard back from AM Solar again, they are having someone else get involved now as well. we will see!
2oldman
Mako_Kupo
2oldman wrote:
GordonThree wrote:
"Everything" being 12v is where I'd get stuck too.
A DC DC converter easily solves that issue.
Mako_Kupo
time2roll wrote:
Have you contacted Victron?
yes, we have been going back and forth for weeks now. both them and the electrical engineer at AM Solar are stumped.
Mako_Kupo
GordonThree wrote:
What was more expensive at 24 volt? Just curious, not trying to undermine your decision.
its tough remembering it all now, but from what i remember - in order to charge my battery bank from my alternator(motorhome) would have cost thousands of dollars, which is clearly insane. i dont have a generator or room for one, so charging from my alternator was a 100% must. then, i had very little room on my roof for 24v panels which tend to be larger. also, i already owned 950w of brand new 12v panels that were already set up and working great(goal zero yeti 1400).
i was stupid when i bought the goal zero and 12v panels, long story short i didnt have a ton of time to choose and there was no way i was building a full system in the time i had.
the lights, fans, switches, everything i bought is 12v and sadly i bought it all and installed before the solar system. unless i wanted to pull parts off the VERY recently finished camper and then spend more money, i was going with 12v.
another big reason was AM Solar is much more familiar with 12v systems, and could provide support. sadly, there support hasnt helped much but they have been trying.
time2roll
2oldman
GordonThree
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
2oldman
Mako Kupo wrote:
edit: sorry, i forgot the main reason was the space on my roof is very lacking, i wouldnt have been able to fit more than 2-3 panels.
Main reason for 12v? I'm not following that.
