Almot
Dec 18, 2015Explorer III
dougrainer wrote:
So, YOU have replaced a EPDM roof? I doubt it from your post. I HAVE. At least 75 over the years. Your post makes NO sense at all. Dicor has no skin by posting the CORRECT procedure. Moving the AC around the roof when replacing EPDM. What a crazy thing to say from someone that has never replaced a EPDM roof. You REMOVE all appliances from the roof as it makes it so easy when you roll out the new EPDM ...
My post would've made more sense if you had read it first :)
1) I never said I had replaced the roof.
2) Dicor sealant does have all the problems that I mentioned - bubbling, shrinking, slow curing. From my personal experience.
3) You can move AC around if you go "liquid way", rather than rolling out new membrane. Was done by others - apparently not by you.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
