Timeking's avatar
Timeking
water at base of toilet - temp fix good idea or bad?
There is a little bit of water at base of toilet, with all indications being failing flange seal. I tightened the mounting bolts a bit, but still leaks ... some. I am traveling and unless I pay to have this fixed by mobile RV guy$$ somewhere, my intention is to put a small seam of DAP Kwik Seal Ultra around the bottom and let it cure overnight.
So am I going to regret this? Will this cause the floor to rot out? I won't get home until November something.
Caulk or not to caulk, that is the question?
