wa8yxm
Jun 27, 2016Explorer III
Clean the filters inside the RV..
There are several possible causes but with two exceptions the solution is cleaning
Clean the fiters (First) as if the filters are dirty a partial vacuum is created above the filters,,, This sucks water (Condensate) out of the drip tray into the area in front of the evaporator coils (Evaporation has nothing to do with water)... Then when the fan slows, or stops NIAGRA FALLS.
Dirty water path (You need to be on the roof to fix this) or alge built up in the wate rpath can cause a steady drip drip even when the fan is running but sometimes the fan will hold the drips up
If the front of the RV is "low" on some designs it may cause the inner lip of the drip tray to be lower than the drip spot causing reverse flow.
But from your description I'd start by cleaning the filters
Icing can do it too, but rare. In fact Icing is more likely an effect than a cause but it can happen, and Dirty filters can contribute there too.
