huskyfan68's avatar
huskyfan68
water heater
went to fire up the water heater over the weekend (testing all systems)- The electric rod that heats the water kicked in fine- I went to turn on the gas (which usually heats faster) and nothing-
I know there is gas since I was running the stove... I believe it's an Atwood 6 gallon- I see 2 reset buttons which I pressed and the gas never kicked in. Any suggestions?
  • Does the WH make a snapping sound when you try to start it? If not you might not have 12 volts to the ignighter. Also check for bug nest and spider webs in the gas burner. Just things I have had happen with mine. Chuck
  • If it has 2 reset buttons it's a Suburban Brand WH (no resets on Atwood)
    The resets are for the ECO (high temp t-stats should they Open)
    Left one is for the electric element
    Right one is for the propane
    Whether using electric or propane their 'normal' t-stats are pre-set to Open at 130*F (The ECOs are pre-set to Open at 180*F should normal fail to open)
    When the normal t-stats Open the water in tank has to cool to roughly 100*F for the -t-stats to Close again.
    Try the propane when water has cooled......open hot side faucet and use the hot water.
  • you are correct. the electric kicks on before the gas heating does. If the water is cool and you still have no gas heating my bet would be on a solenoid. Mine is a 2011 and i have been through 2.
  • I been in the same situation. If I recall correctly, should the water in the tank be already hot - the gas option will not/or may not start. Once the water is cool/cold and the electric option is shut down - it should be fine. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,199 PostsLatest Activity: Feb 18, 2025
