LangsRV2
May 02, 2015Explorer
Water pump is on NO water pressure, Help!
Tuesday we just purchased our 3rd 5th wheel in 4 years. The "new" one is a 2004 Forest River Wildcat 29BHBP. Purchased from a large repulable dealer who says they checked everything to be in working order before we bought it. Actually believable because the tech spent close to an hour with us upon pick up to show us how everything worked.
Last night we driveway camped and hooked up to city water. Everything worked fine. Tonight actual camping away from home filled the fresh water, tank reads 3/4 full. The water pump is running and running not shutting off however there is no water pressure, no water coming out of the taps other than the residual from last night with city water. This RV does have a water filtration system, everything we can see seems to be fine. There is a fitting with a lever which appears to be between the fresh water and the pump. Tried it both ways still no water. No water leaking around the trailer etc. Pump got hot so shut it down since no water is appearing. Logic would say water isn't getting to the pump or it is sucking air from somewhere. The belly of the trailer is enclosed so we can't actually see the tanks but we can easily access the pump. Where do we start? The dealer is over 2 1/2 hours away so we really need to figure this "simple" thing out on our own.
Any ideas?
Any ideas?
