Menander's avatar
Menander
Water pump.
My Sure Flow water pump runs but does not pump water. The water tank is full. ????? Any ideas as to why this might happen? Worked okay a day ago. Thanks in advance.
  • Mine has a decal showing valve configuration inside the bin. My bin has the end of the fresh water tank showing, the valves and water pump.
  • Many Fleetwoods have the water fill in the fresh water compartment. Mine is under a lift off lid near the exterior shower.
    Look in compartment adjacent to the city water connection.
  • enblethen wrote:
    Is this on the Bounder?
    Check to see if fill valve is in the correct position if equipped.
    It is the Bounder....not to sound like an idiot, but where would a fill valve be?
  • Is this on the Bounder?
  • Air bound......open a faucet and let it run to expel trapped air
    Air in leakage.....pump can't prime due to sucking air in on suction side of pump.
    Cracked pump casing, strainer loose/cracked, loose hose clamps. winterizing valve open
