Lowcountrydupre's avatar
Feb 25, 2014
Wedgewood Range Burner
Has anyone had to replace their range burners? If so where did you go to get replacements? I have a Wedgewood RV-2135 BBPR and the piezo went out on the 9000btu front burner. I can still light it with a match, but like to get a replacement.
  • LowCountry, I had the same problem. I noticed that the ignitor wire for that burner had been pinched under the feed tube. Got it out, a little black tape, and good to go.
  • Before you replace the burner check to see if the wire to the igniter has come louse or disconnected.
    It would be a lot cheaper to buy a new igniter kit for a BBQ at Wal-Mart.
Having RV issues? Connect with others who have been in your shoes.24,256 PostsLatest Activity: May 22, 2025
