6_7lPSDFORD
Nov 16, 2021Explorer
Skibane wrote:
Are you sure that 30 amps is the correct size fuse?
Your power converter is capable of supplying 45 amps.
If your batteries are drawing that full 45 amps through a 30 amp fuse, it's gonna blow.
30 amps is what the sticker states on the power converter and its also what was in them from the beginning, Im leaning more towards bad batteries, I think I might have them tested, because I do not understand why the batteries would demand that much from the converter to blow a fuse, maybe a bad cell I don't know.
I suppose I could up the fuse size but I need to look at the wiring amp rating so I don't start a fire.
