SCVJeff
Apr 04, 2016Explorer
Gjac: I've had the same problem getting fine debris, in my case likely salt, just inside the burner and that will cause the flame to yellow up, AND pre-detonate the LP in the chamber. That causes it to backfire. The first time that happened I cleaned and scraped, blew it out, and never did get it where I wanted it to be. Its amazing the tolerances on these things. I might build a little mix slider, but at sea level shouldn't have to.
Chris: I'll look at that too, but to be clearer, the flame isn't going out above the burner, its igniting within it and I observe flame coming out the 4 air vents. When that happens there is no reignation spark because the flame never went out. Strange eh?
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 26, 2025
