doublev
May 26, 2014Explorer
When is it time to replace house/engine battery?
I have a 2008 country coach (delivered jan 2007). I have replaced the engine batteries before but not the house. I replaced the engine about 3 years ago when the unit lost power for six months (circuit breaker). So the deep cycle also took a little beating back then.
I am going through the motorhome and freshening it up (new tires, full engine service) and want to look into the batteries.
How do you properly load test the batteries? Disconnect from shore power, some 1kw of load and see if voltage is about 12.5? How long should it take before it falls below 12.5 or whatever voltage is deemed to be sufficient?
