MrWizard
Jan 13, 2018Moderator
over heart When ?
off level the temp is right , but fluid is not returning to correct point in the system
over heat during a malfunction ? I think that would require some kind of internal pressure switch, burner seldom fail my getting to big a flame and too much heat
a leak in the system creates a loss that raises pressure, the fire happens when the hydrogen gas leaks/erupts from the bursting pipes
i think that infamous recall fix from a few years ago
involves a heat sensor
and the electronics can only be reset a limited number of times
then the whole thing has to be yanked and replaced !
Having RV issues? Connect with others who have been in your shoes.24,192 PostsLatest Activity: Jan 26, 2025
