Due to a leak in the window of the entry door, I removed the window today (standard two part plastic frame, sandwiching a single pane piece of glass) to clean things out and replace the sealant/gasket...
Use butyl rubber tape and peel off whatever oozes out. Do not be overly generous about applying it as too much will add enough pressure while trying to squeeze the sides tight to strip the screw holes.
