IWanda
Aug 04, 2016Explorer
winnebage 2016 View airxcel 47000 icing up
Hi - I have just purchased a Winnebago View and the a/c stops working on low fan setting after a few mins. It comes back on about 30mins later only to stop again after a few minutes. The a/c works fine on high fan. I have been back and forth several times with Lazydays on it and they finally changed the unit. The replacement unit is now doing the same thing and stops working on low fan. The manual for the a/c does say this may occur at temperatures of 76 degrees and to set the thermostat higher or run it on high fan. We live in Florida with high humidity and temperatures in the high 80s. I have seen a few posts on other forums where this occurs and was wondering if anyone else has the same issues with Airxcel units.
Jon
2016 Winnebago View
Jon
2016 Winnebago View
