njtony
Nov 25, 2019Explorer
Winter camping
First time winter camping. I have a heated water line but not sure if I hook up to fresh water inlet or on board tank . I have 2013 coachman class a. It has a heated under belly.
agesilaus wrote:
Fill up your fresh water tank disconnect and drain all hoses. Use the water pump for water.
Lynnmor wrote:
Unless the hydrant is heated, it will freeze if a hose is connected.
