suprz's avatar
suprz
Wire size?
Just making sure, low power LED strip less than 5ft, and the power wire is less than 3ft long. Can I use 20 gauge wire for the 12 volt power and ground? I don't believe the LEDs will draw more than an amp IF even that much
  • wa8yxm's avatar
    wa8yxm
    Short answer: YES
    long answer It might be "overkill"
    But to be sure.. measure the voltage at both ends of the wire. I'd not worry about 1 volt loss or less.
  • suprz wrote:
    time2roll wrote:
    s/b fine. Consider a 5 amp fuse on the branch circuit.
    On the power IN, or the power out?
    At the point that you connect the #20 wire to the positive battery supply.
  • 2oldman wrote:
    I can't find a single ampacity chart that rates a 20awg wire. What is that, speaker wire? Anyway, it'll be ok, but don't put anything else on it.
    CHART
    20 AWG will work fine. My under cabinet lights in S&B is 8'6" and running on a 2 amp ps and #20 wire.
  • I can't find a single ampacity chart that rates a 20awg wire. What is that, speaker wire? Anyway, it'll be ok, but don't put anything else on it.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
