MrWizard
Sep 15, 2023Moderator
The corrosion came from out gassing, flooded batteries on constant charge in hot weather are going to outgas, which is why you are adding water every month , its good you check them and fill them, you might consider a disconnect switch for the batteries, and let the power converter supply the trailer, once a month connect the batteries for 24 hours for Top Up,
Keep the batteries in reserve for power outage situations, this will prevent corrosion and increase battery life ,
I like AGM batteries, they don't out gas under normal use, they are valve relieved, they will outgas if over charged or overheated,
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
