littlesonny
Nov 22, 2017Explorer
Xanrex Inverter/Charger Over Charging
We had a solar panel and inverter installed when we bought our Jayco Whitehawk TT as well as converting the 12 volt to two six volt batteries. Expensive ones. The first time we used the inverter while dry camping it blew out the batteries, TV, and fried the inverter itself.
Back to the dealer who replaced everything at no cost including a newer upgraded inverter. They admitted they had screwed up the installation somehow.
Next time we took the trailer and hooked it up to shore power the inverter control panel showed an error message E10, overcharged batteries. Back to the dealer, who also did some other work. They said it was working fine there. Service manager said something about turning it off when not in use. Thing is, according to the manual you don't have to shut it off. Everything works automatically. But okay at the dealer the panel was reading normal.
As soon as I got it back and hooked up a shore line, after a short time once again the same E10 overcharging message.
Before I take it back to the dealer yet again I was wondering if anyone else has had a similar situation. I also wondered if somehow the solar panel and the shore line both feeding current to the batteries might be the problem. At the dealer it was in a covered shed. Only thing I could think of not having a clue how these things work.
Any thoughts or suggestions would be greatly appreciated. BTW, Xantrex support says the fault is not with the inverter.
