HouseApe
Mar 25, 2019Explorer
Yamaha EF3000iSE neutral bonding issue - Solved
I have a bit of a head scratcher.
I have a Progressive Industries HW50C and have made my own neutral bonding plug.
I’ve use that plug with my old Yamaha EF2400iS (2007 USA model) generator without issues or codes on the PI unit.
Got a new to me EF3000iSE (2015 Canadian model) with low hours. It runs perfectly fine. However I keep getting code E2 Open Ground on my PI unit.
Knowing that the 30 twist lock on the generator was a bit loose I summerize this was the issue.
After paying big $$$ on a genuine Yamaha 15 amp and 30 amp replacement receptacles the issue is still the same.
I know I can just put the PI into bypass. It’s readings 123 Volts @ 60 HZ with the E2 error.
I’ve double checked my bonding plug and did a continuity test on the 15 & 30 amp grounds and checked them against the ground stud. They are all connected.
So why can’t I bond the neutral with my plug like my old (and now sold) EF2400iS?
