โAug-18-2013 07:38 AM
โAug-19-2013 09:51 AM
โAug-19-2013 05:47 AM
โAug-19-2013 05:31 AM
lfeather wrote:Ailurophilia wrote:
Any one else have any more ideas or advice?
Does it work on electric?
โAug-19-2013 05:26 AM
โAug-19-2013 05:11 AM
โAug-19-2013 04:51 AM
โAug-18-2013 09:28 AM
Don McL wrote:
is it lp gas or ammonia gas your smelling?
ammonia smell would indicate a leak in the evaporator section
don
โAug-18-2013 09:27 AM
downtheroad wrote:
There should be a safety shut off/lock out on the frig. If it doesn't light after a couple of tries, the gas to the fridge will be shut off and should certainly not be filling your rig with propane.
โAug-18-2013 08:42 AM
โAug-18-2013 07:58 AM
Ailurophilia wrote:
Yes, but could it be leaking due to the gas coming out the line, but not being lit? Stuck thermostat or like? I will have to check the gas alarm indeed!
โAug-18-2013 07:50 AM
downtheroad wrote:
First thought, wondering why you didn't set off a gas alarm??
Obviously you have a leak somewhere in the line. Obviously a very dangerous situation.
If you can't track it down, it has to go to someone (dealer or RV repair guy). We have mobile outfits that can come to your house or site.
Good luck with it.
โAug-18-2013 07:44 AM
