โJan-12-2018 11:37 AM
โJan-15-2018 05:02 PM
โJan-15-2018 04:54 PM
โJan-15-2018 04:44 PM
โJan-15-2018 12:42 PM
โJan-15-2018 10:59 AM
โJan-15-2018 10:02 AM
Bobbo wrote:
When plugging in a portable solar panel, the SOLAR PANEL'S POSITIVE is wired to the covered connector.
โJan-15-2018 10:00 AM
Bobbo wrote:Doing so would only result in a connection which wouldn't do anything useful/good, as any connection would have crossed polarity.
When wiring this type of connector, you always wire the positive wire to the connector that is covered, and the ground to the connector that is exposed.
Bobbo wrote:Which only means the trailer side connector has its exposed contact connected straight to the battery +.
When plugging in a portable solar panel, the SOLAR PANEL'S POSITIVE is wired to the covered connector. This follows the standard.
โJan-15-2018 09:49 AM
โJan-15-2018 09:30 AM
โJan-15-2018 04:25 AM
โJan-15-2018 04:08 AM
โJan-14-2018 03:50 PM
rbp111 wrote:
I you connect a "regular" solar panel to a Zamp wire connector which has reverse polarity, what happens? Does the unit not work, or does it do any harm?
โJan-14-2018 05:32 AM
โJan-14-2018 04:49 AM
