mekkerl wrote:
Geesh $1k to $1,500????!!!! ....
The slimmer wallet is the biggest hesitation I have in bringing this to a dealer.
I'm by all means handy with tools, but this big truck worries me as we have the big trip this year.
I didn't mean to scare you and I could be shooting high, but the $250 price tag just for all the fluids is probably about right. You might call your dealer and tell them the list and get a bid for the work just so you know.
Here's what you can definitely do at home:
Oil ChangeYou can get oil and filter for about $50 if you use standard 15W40 or about $75 for 5W40 synthetic. A big drain pan and a filter wrench are all you need.
Fuel FilterThis is easy too. Drain filter, remove filter, spin on new filter, cycle key 4-5 times to prime (off-run position-off) then start.
AxlesThe front axle has a lower drain plug so it's easy to service. The rear will need the differential cover removed. Or, you can get a vacuum oil extractor like this
Topsider multi-fluid extractor and just suck the gear oil out through the fill plug. I use one of these on my boat and it works great. If the diff cover isn't leaking, this is a great option for pulling out the oil.
Transfer CaseThis is also a drain and fill plug setup. Remove both plugs to drain it. Replace the drain, fill from the top until it runs out, replace the fill plug.....done and done. You MUST use the GM Auto Trak II T-case fluid. It's really pricey ($10/bottle) and it takes about 1 1/4 bottles so you have to buy 2 of them. But, paying the $20 and 30 minutes of your time will probably save you about $100.
Brake line flushBleeding the brake lines can't get any easier than using the
Motive Products Power Bleeder. Use a turkey baster to remove fluid from the master cylinder then top off with fresh DOT3 fluid. Put the master cylinder cap adapter on then pump up the bleeder to about 15PSI. Now go to the right rear, open the bleeder valve and drain into a cup until it's clean, clear fluid coming out. Now cycle to the left rear then front and you're done. Fresh fluid all around.
TransmissionI believe servicing the Allison transmission only involves removing the spin-on filter and then topping off the fluid. No R&R of the pan and internal filter.
So yes, for the DYI tasks you'll have to spend about $125 in tools (bleeder and extractor). But, you buy them once and you can use them for many years.
Really the only things I think you might want to hadn off to the dealer are the power steering, coolant flush, brake check, and belts/pulleys. Both the power steering and the coolant can get really messy and there's no good way to dispose of DexCool at home. If you're not comfortable inspecting brakes and belts then you probably will want a 'trained eye' to look over that. But.....just about any shop can do these things, it doesn't have to be a dealer.
Just an FYI.....if you do a complete brake pad and rotor swap on these trucks, you'll spend $550 in parts alone! Yeah, I choked too as I typed that but I've bought the parts before. That cost is another one of the driving factors of why I do almost all of my own work.
KJ
