srschang
Aug 29, 2017Nomad
adamis wrote:Redwoodcamper wrote:
I used the renogy 200watt kit with normal panels and used eternabond to tape them to the roof. Been 1000+miles and over 80mph on occasion with them not moving.
Thanks for the report. I do have a question about the eternabond tape you used. Do you have any concerns about being able to remove it from your roof should the panel ever need to be replaced? I have a fiberglass roof and though I'm confident the adhesives will hold, I am a bit concerned about what damage it may cause if it ever needs to be removed.
Although I attached my solar panels with screws, I did some leak repair with Eternabond tape several years ago on the roof of my camper. It IS removable, I'm in the process of removing it right now. Removal is painstaking, plan on 2 minutes per inch of tape to remove. So a 2'x4' solar panel will take about 5 hours to remove & clean up. But it is possible.
44,027 PostsLatest Activity: Apr 19, 2019
