darlingtontrio's avatar
Mar 29, 2014
12 volt problems
Hopefully someone can tell me what to check. When I unplug 110 volt from my TT, I get nothing working at all. I have checked the battery and it has 13 volts. The battery is also plugged into the wiring harness on the tongue. I grabbed my volt meter and when the TT is plugged into 110, the low voltage breaker is working. The power inverter is also working, the light and the fan are working on the power inverter. When I unplug the power inverter, everything dies, which I assume it should. When I pull the 110 power, the low voltage breaker reads 0 volts. Where should I look to figure out why I am not getting any 12 volt power. I am sure there is something, but I am new and not sure where to start. Thanks in advance.
