Crabbypatty wrote:
While I understand that folks are buying the Champions, the jury is still out on how long they will last. Having camped next to champions they are not as quiet as the Hondas. My Honda 3000i just celebrated its 14th birthday so that amortizes really well. Annual oil change and it has its second spark plug. It is heavy though so if you can mount it that makes it easier and you can get a remote start kit for it. We solared 3 years ago and wished we did it sooner so we haven't used it much. recently bought a Honda 2000i. While it will not turn your ac, two will. I liked the 3000 as the wife could just turn the key and 3.6 gallons goes 24 hours not under full load, so carried less gas
As far as I am concerned after investing over $60k in truck and trailer Im not going to screw around and spend less on something that hasnt been around that long. As soon as it blows up, which I hope it doesn't, you've lost when he Honda keeps going. Some times you needs to spend more for peace of mind and less aggravation, which is what I do.
This works for me
With its excellent reliability,
extremely quiet operation, and as you mentioned, its ability to run much longer on a tank of gas, the Honda EU3000iS has the edge over the Champion 3xxx inverter generators.
In terms of price (50-65 percent lower), less weight, and much higher inrush current capability, the Champion 3xxx inverter generators have the edge over the Honda EU3000iS. Don't underestimate the advantage of high inrush current capability. This gives the Champion 3xxx inverter generator the ability to start and run significantly more RV a/c units than the EU3000iS, especially 15k units.
The Champion 3xxx inverter generators have been on-sale/in-production for 5 years now. Based on the high number of positive online reviews, it's obvious they've been selling very well, and have no significant reliability/quality issues. After 5 years of "jury" deliberation I believe it's reasonable to assume the Champion 3xxx inverter generator is not a ticking time bomb.
Last, but not least, IMO, Champion has more responsive and consistent tech and warranty support than Honda. With Champion you get warranty and tech support directly from the manufacturer. Honda's warranty and tech support is all 3rd party, via their authorized dealer network. Expertise and service tends to vary from dealer to dealer.
Bottom line, both generators have their own respective set of pros and cons. The
better generator is in the eyes of the beholder.
