Vinsil's avatar
Vinsil
18" wheel options?
Is there any options for a 18" wheel that has a 4k+ capacity? I'm not finding any and haven't found specs on factory Ram aluminum wheels but assuming they are rated lower.
  • Thanks for the replies. Mike, 3500 is just not enough...darn!
    The H2 wheels are popular but unfortunately they are 17's......
  • My 18 inch OEM Ram wheels were rated for 3,500 lbs. My new HD Series Cranks are rated for 3,600 lbs. I like the look of them, and the with the larger weight rating, I'm pretty happy with them.
  • Not directly answering your question, but I run Nitto Dura Grapplers rated at 3970#. I have them mounted on OEM GM 17" STEEL wheels.
    My thinking is any failure would be bending instead of an alloy wheel cracking.
    I keep the OEM tires mounted on OEM alloy wheels for winter (non-rv) use.
    But IIRC weren't Ram owners finding Hummer alloy wheels (rated at 4000#?) that would fit their trucks?
  • jimh425 wrote:
    I don't know of any wheels that are rated that high, but the Ford wheels rate to 3750, so I assume the Dodge have something similar. Worse case, you are slightly over their rating.
    Good to know. I'd be happy with wheels at 3750. Anyone confirm Ram is same?
  • I don't know of any wheels that are rated that high, but the Ford wheels rate to 3750, so I assume the Dodge have something similar. Worse case, you are slightly over their rating.
  • Buzzcut1 wrote:
    that load rating puts you into the 19.5 wheel category
    Understood, but have been attempting to avoid it as I have found a E range tire that gives me 4080 lbs of capacity....but haven't found a wheel to match.
