Henry_Wall's avatar
Henry_Wall
1999 Fleetwood Mallard
I have a 1999 Fleetwood Mallard 24j that some one modified and and put the fresh water tank under the master bed I would like to put the tank back in the original location could anyone tell where the fresh water tank and pump are supposed located and I can find a wiring diagram the V.I.N./N.IV. number is
1EF1J242x2468396 and I don't know if this is of any help but there some more letters and numbers on the sticker CSA Z240 Series Issue R 195771 24J
❚ Did you see the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions, as doing so can delay responses to your thread. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
  • not all 24J s come with a couch mine doesn't have a couch and my owner's manual says if equipped
