โApr-27-2017 02:46 PM
โMay-03-2017 09:30 PM
โMay-01-2017 06:46 AM
โMay-01-2017 03:20 AM
Camper G wrote:
A lot of new rotors these days cannot be turned as in years past unfortunately. The rotors are not made as thick and can't be turned many times and still be above minimum thickness.
โMay-01-2017 02:50 AM
โApr-30-2017 09:44 PM
โApr-30-2017 05:07 PM
โApr-30-2017 05:28 AM
โApr-29-2017 07:43 PM
โApr-29-2017 01:32 PM
โApr-29-2017 12:54 PM
FloridaReLoaded wrote:AlmostAnOldGuy wrote:
Your rotors should not warp, maybe the trailer brakes are not doing their share of the work. Do you have the integrated brake controller? If you do go ahead and reset the brake controller setting as described in the manual and you should be good.
Good luck,
Stu
Okay they replaced the throttle body and it appears to have fixed it. Thought about trading it in but after looking around it seems as tho they just don't make trucks like they used too. So I'm thinking of just keeping this one and hoping and praying for the best.
Now to my warped rotors, first of all I do have the integrated brake controller and I have it turned up to the max setting of 10. Ive had others brake controllers on previous rigs so I know how they are supposed to work but this one is NOT making the trailer do it's share of the stopping. With the controller set on 10 (max) doing 25 mph and sliding all the way over it just slows the trailer down. It does NOT lock up the trailer wheels like it supposed to. Now the trailer is only a year old so its basically still pretty new. But is my problem with the travel trailer brakes or with the integrated brake controller?
And thirdly, since Ive already been told that both the rotors and brake pads will more than likely have to be replaced, will it hurt it to continue driving it like it is. The shaking to me when applying the brakes is bearable.
thank you
โApr-29-2017 09:46 AM
โApr-29-2017 08:57 AM
โApr-29-2017 08:44 AM
Good luck,
Stu
โApr-28-2017 05:44 AM
