- wintersunExplorer III added the double leaf Supersprings to my 2500HD pickup and it provided it with a 5,000 lb. payload capacity. It took only one hour to install them with some wrenches and a large C-clamp. Nothing to adjust and nothing to fail while out on a trip. The ride without the camper is not different than before I installed them. The shocks don't have to work as hard as the added springs reduced the range of travel of the truck at the rear with a 3700 lb. camper load.
With SuperSprings you are increasing the load capacity of the factory leaf packs but not changing the way the function. This is the opposite of what happens with air bags.
Search for the many posts by people with handling problems with their air bags and also the posts by people who had air bags on their trucks and then took them off. Air bags are good for tow vehicles to adjust the height of the hitch or the bed to better mate to the trailer. If one of the two air bags fail, and they will sooner or later, you will have to abort your trip until they can be repaired. They would be my very last choice for this reason alone. - BoatycallExplorer
deltabravo wrote:
wcjeep wrote:
Airbags can unload the suspension. Stable Loads engage the suspension sooner. Stable loads first.
Ditto.
I wish I'd have installed StableLoads First, and I would never have spent the money on airbags.
Stableloads do a lot more for me than the airbags - AF811 on a 2009 Silverado Dually.
I have an EXTREMELY heavy camper, I run Stableloads. They will never pop or leak. - bighatnohorseExplorer III added a set of SuperSprings (5000 lb rating) and find that the truck is still low in the rear.
I like the way it rides and really don't want to add airbags. But airbags appear the only way to make it level, short of adding some type of lift kit or trailer with weight distribution system. - Reddog1Explorer II
twodownzero wrote:
While I agree that heavier springs would be a better solution than airbags, I remain unconvinced that stableloads--which seek to add only one or two leaves (the overload leaves) provide a sufficiently meaningful increase in spring rate. I say this because I have had my truck loaded to the point that the rear overloads were compressed almost completely and they really didn't do much to help level the truck (otherwise it wouldn't have been squatting so badly, and it wasn't overloaded by much and the rear tires were not overloaded).
Airbags, on the other hand, will virtually completely level the truck even if it is grossly overloaded. I'm convinced that the mounts would break before the airbags would cease to support the weight.
As such, I run airbags with about 60 psi when loaded with camper. If I had a heavy trailer I'd just add more air.
This has been my experience also.
Wayne - twodownzeroExplorerWhile I agree that heavier springs would be a better solution than airbags, I remain unconvinced that stableloads--which seek to add only one or two leaves (the overload leaves) provide a sufficiently meaningful increase in spring rate. I say this because I have had my truck loaded to the point that the rear overloads were compressed almost completely and they really didn't do much to help level the truck (otherwise it wouldn't have been squatting so badly, and it wasn't overloaded by much and the rear tires were not overloaded).
As such, I run airbags with about 60 psi when loaded with camper. If I had a heavy trailer I'd just add more air. - RoadloverExplorerIn my case, I started with air bags but I was still not happy with the ride. I installed the Sableloads and it was a night and day experience. So much of an improvement, that I only left enough air in the bads to keep them from getting pinched. The Stableloads cost so much less that I would recommend your parents try them first and if not satisfied, then try airbags.
Ken - Big-wheelExplorerThanks everyone, I think he has decided to do the Stable loads. We will see how that does and go from there.
- kbaumExplorerInitially put on air bags and then stable loads (lower). Currently, only use a small amount of air (20 labs) and let the stable loads do the rest. I really just use the air bags for leveling, if I only had one I would get the stable loads .
- cubbearExplorerI have a 2015 F 350 LB CC DRW PSD New artic fox 990 I gross 14430 loaded I put lower stable loads on before I picked up camper. have driven through a lot of wind no problem.
- BedlamModeratorThanks. My F250 with AF811 and trailer hitched up was about ton heavier your setup and I was pulling four tons behind me.
About Travel Trailer Group
44,027 PostsLatest Activity: Mar 05, 2025
