arkie_guide
Oct 03, 2017Explorer
To keep my mind satisfied, I ran a separate wire TV battery, to Rv battery to charge while traveling. + terminal on battery, to 30 amp circuit breaker then to rear of TV and a plug there to hook RV battery to. Also use a battery disconnect. The typical 7 wire pin on RV wiring is good but the hot + wire, will not do a good job of charging the battery when traveling.
just my way of doing things.
44,030 PostsLatest Activity: Jan 20, 2025
