2017 Ford F250 6.2 Gasser Radiator Drain
2_many_2
Deleted
21 REPLIES 21
theoldwizard1
2017 is WAY TOO EARLY to change the coolant ! I have a 20 year old truck and the coolant has only been changed TWICE, the last change was about a year ago ! If was amazingly clean !
When you DO need to change the coolant I highly recommend staying with the appropriate Motorcraft brand.
Pg 580 of the 2015 F250 Owner's Manual recommend first coolant change at 100,000 miles, 60,000 miles if towing !
Grit_dog
Navigator
Navigator
Iโ€™ll let you come do a couple coolant changes for me so you can get it out of your system....
carringb
Honestly I'd leave it alone. The new coolants last a very long time as long as oxygen isn't introduced. You may inadvertently shorten the lifespan of your cooling system by periodically draining and filling. There's good reason why they've made it harder to service.
2014 ORV really big trailer
2015 Ford Focus ST
2_many_2
Deleted
Groover
If it is cross flow you may be able to just siphon the coolant out. I assume that you have a good reason to want it out but it should be good for at least 5 years.
agesilaus
I believe radiator drains are a thing of the past. They want you to get a radiator flush when you change the antifreeze now.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
Sportsmen
You will get a better response to this question at Ford-Trucks.com
https://www.ford-trucks.com/forums/forum279/
2016 Jayco Jay Flight 27BHS 6210 empty, 8200 GVW
2016 F250 CC 6.2L(gas) 3:73 diff (3157lb. payload)
