Nope, no issue that I've seen or heard and fwiw, the fuel system is basically the same from 03 to present on these trucks.
By the same token, regular use of an anti gel like PS 911 is not reccomended nor needed. It's to liquefy a system already gummed up.
Other products are generally not needed at all either unless, say there is an abnormally, almost record cold snap for a particular area, where the fuel may not be treated down to that temperature, or if you're traveling to a significantly colder climate on fuel bought in a warm climate.
Needing a winter additive anymore is purely wives tale for most normal use. Commercially purchased fuel is and has been blended for the weather in the area for years.
