'21 RAM Big Horn 3500 DRW CC/LB 4x4 with NEXEN Tire WOES!
Jack_in_Dixie
Both OEM NEXEN front tires (LT235/80R17E) had to be replaced last week due to separation with only 11K miles since I purchased the truck FEB-21. Wish I had known (or researched) these POS tires before I signed on the dotted line or I would have insisted on Michelin Defenders I have always used in the past before I left the dealership. My bad...
I have ZERO trust/faith in these NEXEN tires. Therefore, I am going to remove/replace these crappy tires this week. My problem is finding a Michelin Defender LTX M/S or Michelin LTX M/S2 in my OEM size tires (LT235/80R17E). Only Michelin tires I can find in my size are the LTX A/T2, Energy Saver, and Agillis???, none of which I really want to pay $2K for. I NEVER had so much as a flat tire in the the 20+ years I rode on Michelin Defender LT tires hauling RVs around the USA!
Is there another SIZE TIRE that will fit on my 17" wheels so I can try and find a Michelin Defender LTX or LTX M/S set of tires? If not, looks like I will be buying new wheels also...
Thanks in advance.
Jack in North Florida, Retired
River Life on the beautiful Suwannee River
2021 RAM Big Horn 3500 DRW CC/LB 4x4
2021 Keystone Cougar Half-Ton 29RKS
40 REPLIES 40
blofgren
Jack in Dixie wrote:
PROBEM SOLVED: As a few members posted, an LT245/75R17E size tire will fit the 2021 RAM 3500 1-Ton dually. Was also able to find the tires I wanted all along in that size tire... the Michelin Defender LTX M/S and/or a Michelin LTX M/S2 tire.
Bought a set of 6 Michelin LTX M/S2s from Tire Buyer dot com. These are the same tires I had on my previous Tow Vehicle (2011 RAM 2500 CC/LB 4x4).
Hopefully this post will help someone else to DUMP the NEXEN tires and find a good Michelin Defender/LTX M/S2 set of replacement tires for a RAM 3500 DRW Tow vehicle. It was a costly lesson for me, but now I have 100% confidence in the tires to drive with peace of mind and comfort. Hard to put a price on that...
THANKS to all for your inputs, even those with the snide comments. I won't bother with another 'silly' post or 'complain' on the forum again.
Jack
Thanks for the follow up. And after reading this thread this morning, I realized that it is indeed 245/75/17's that are available, not 245/80/17 as I stated previously. It's been a couple of years since I replaced my tires. 🙂
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
cummins2014
Cummins12V98 wrote:
cummins2014 wrote:
Cummins12V98 wrote:
Learjet wrote:
Cummins12V98 wrote:
Learjet wrote:
38,000 miles on my Michelin LTX MS2 tires and they have been great and are wearing great!
I assume you had your front aligned to nearly ZERO toe???
No alignment changes...still set from factory.
I have seen your post about that...but I never had an issue with wear on the front tires. I do rotate the front tires only side to side every 10,000 miles. All good so far 🙂
VERY interesting!!! Are you the original owner?
I had my truck set to the Thuren specs after the drag link recall replacement from whatever it was to near O toe. I too have never had any unusual tire wear prior to this alignment , hope that doesn't change ,setting to these Thuren specs . This is my third set of tires .
Not sure how much water this holds ,this near 0 toe . Been hearing this since I've owned the truck . We will see . I see no difference in handling , road wander etc . This is the first alignment my truck has had since new , 9 years . Not sure why, mostly because I had the drag link replaced .
To add my son is on his third Ram since 2008 , and its used daily for work ,lot of miles ,and he's never had one of his trucks aligned ,and again no unusual tire wear . Beginning to wonder about this 0 toe thing . Kinda funny that the manufacturer of these trucks don't set the toe to nearly 0 ,makes you wonder .
I don't believe I have ever recommended the near ZERO toe spec for a SRW truck. I only comment and recommend this to DRW trucks.
Didn't say you recommended anything. Thuren recommends it , and yes they recommend it on SRW , same reason you recommend it for DRW .
Cummins12V98
yes, original owner bought new...less than 20 miles on it when I picked it up. Maybe, I got lucky 🙂
You are lucky!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
Jack
I have to ask what are the date codes on the obsolete MS2's???
Cummins12V98
Learjet
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
blt2ski
Moderator
Moderator
ive only had one Micheblow tire that was any good, that is was an XDE M+S in a true truck tire 225-70-19.5 LRG tire. ALL of the LT or P metric tures didnt do so well. Glad micheblows work for someone generally speaking.
In the meantime, I've found Cooper to be better tgan micheblows. Toyo too, but they are asking for too many of my kids per tire. Good Year a mixed bag......
Glad OP has issue fixed?!?!?!?.....
marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
fj12ryder
"THANKS to all for your inputs, even those with the snide comments. I won't bother with another 'silly' post or 'complain' on the forum again."
Ya gotta ignore certain members, who really try to post like members, "dicks" IOW.
Howard and Peggy
"Don't Panic"
Jack_in_Dixie
Jack
cummins2014
Cummins12V98
Learjet
B&W Ram Companion
Cummins12V98
Had Manager at a NW WA Discount Tire give me a price out the door $2,004.24 for the Michelin LTX AT2's six total for my RAM DRW.
Costco was $2,097.44 I think that was without tax.
spoon059
time2roll wrote:
I recommend Goodyear Wrangler® All-Terrain Adventure With Kevlar® that is available in that size for far less than $2000. This is top line GY and will serve you well.
I have these on my SRW Ram truck. Just got an email from Goodyear that they are running their Memorial Day sale. Use a Goodyear credit card for an additional rebate. I really like my tires.
2015 Ram CTD
2015 Jayco 29QBS
