jerem0621
Nov 12, 2013Explorer II
4 cyl can tow!
My little 2013 Sorento had its first towing test tonight right up to its max tow rating of 1650 lbs. it was probably loaded at about 2000 lbs total including the trailer. There were 44 boxes of 8mm laminate flooring on the trailer.
The trailer was loaded appropriately and was slightly nose down orientation before I loaded it tonight. I forgot to accommodate for the weight. I will correct that issue. The skid of flooring was slightly forward of the axle. It was extremely stable not one hint of sway.
The little 4cl pulled the load extremely well and exceeded my expectations. (ya gotta have a truck to tow anything right?) I had my wife and our two sons in the Sorento. 6 rolls of underpayment and two more boxes of flooring in the trunk.
I am confident that this little rig would handle a 1500-2500 ish lb pop up without even blinking. Especially with a transmission cooler. (Which I have not added)
I have a nice Curt 3500/350 lb WC only round tube hitch and a vehicle specific 4 way wiring harness.
I will probably add brakes to this utility trailer and to a future pup which means adding a brake controller. No biggie really.
The Crossover design seems to be a stable towing platform. Coming from a F350 with a 31 ft TT I had my doubts about the Unibody. Granted we are not talking about a 5-10k lb trailer.
When I was installing the hitch I was somewhat surprised at the beefy structure under this rig. The rear suspension is independent and handled the trailer extremely well.
Anyway. Here's a pic of our little rig all hitched up. I can't wait to get a PUP and get back out there camping.
Thanks,
Jeremiah
Thanks,
Jeremiah
