7 Pin Trailer Connection falling out of TV outlet
Clamdigger213
I have just picked up my new TT Avenger 35 RDS from the dealer. When dropping off my new trailer at the storage unit. I had to stop two times to make the 7 Pin connection. It falling out of the connection. Is there anything that I can do to stop this from happening?
TV 2013 RAM 4x4 Crew CAb
TT 2015 Primetime Avenger 35 RDS
27 REPLIES 27
mabynack
10by32 wrote:
I always secure mine with one of the mini bungee cords. Learned the Harry way what happens when it drags on the road for a while.
Me too. I now have an outlet in the bed of my truck and I trimmed the excess wire so it won't happen again.
schlep1967
Another possibility is the cord is too short.I ran into this pulling a borrowed trailer. Every time I turned left it unplugged the cord.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
samsontdog
I do the same as above
samsontdog:o:W
hawkeye-08
I always connect and disconnect a few times before I connect to "clean" the contacts a bit and then make sure the cover secures the cord. I had some trouble when truck was new getting it in far enough to latch, but after some usage, it latched fine and stay connected. I carry the mini bungees and would use that if needed.
kearlms
nevadanick wrote:
Your not pushing it in far enough. The flap or door has a stop built into it that the keeps the plug from coming out.
I have a similar issue as the O.P., but it is not a matter of pushing it in hard enough. I can really but pressure on mine and it will back out a bit. Not enough to fall completely out but just enough to loose contact. I replace the one on the TV, been contemplating replacing the end on the TT.
I always make sure that the clip on the lid is holding the plug in.
icanon
X3
Loving wife and 2 beautiful daughters.
Chocolate Lab, Lily
2014 Dodge Ram Laramie Hemi 5.7 with 3.92
2014 Dutchmen Kodiak 290BHSL
ProPride 3P Hitch
Progressive Industries EMS-PT30C
Love my Weber Q1200
Me a Happy man on retirement!!!
tropical_ron
I had a similar problem where the umbilical came loose behind my motorhome at the connection from the car 7 pin connector. My remedy is to use velcro strap to ensure that the connection stays firm. 5 years of worry free connection. My issue is the umbilical is heavy duty cable like used on trailer trucks and is very firm and always has spring tension. My fix works great for us. I use velcro straps at both ends of cable. Good luck.
2007 National Tropical T370 LX CAT-350
2010 Honda CRV awd
Blue Ox Baseplate
SMI aux. brake
Tvov
Is the plug actually falling out of the connection, or coming loose and almost falling out? Most plug receptacles have a hinged cover that has a lip on it that will grab the plug, preventing it from falling all the way out.
A plug can still come a little loose, though, and also some of the connectors inside the plug can get worn.
But... with your trailer being so new, maybe the plug came from the factory defective? Replacing the plug may solve all your issues.
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
Road_Runners
If all else fails replace the receptacle on your truck. I would suspect that the spring on the lid of your present receptacle is broken and won't hold the plug from the trailer firmly.
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
Baja937
X2...You've got the same "Blade" type connector as I do on my 2014 Ram...
Make sure the trailer is a "Blade" also...
You're trying to spread the female blades open and insert the males...It's a tight squeeze so the connector stays on...Work it gently but push hard and it'll sit nicely...They mate real solidly...
There's some camp chatter for ya'!!! lol...
RoyB
They use to snap in place with strong lids with the older models trucks. I know my 2010 model Ford does not do this very good as well,
I use the small bungee cords to hold mine in place as well...
I just wrap the bungee cord around the cable an pull tight to hook into the two side eyelets that most of the trailer hitch receivers have.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
nevadanick
10by32
