RoyBell
Jul 12, 2017Explorer
Added 12V USB outlets
Finally pulled the trigger and ordered some. USB outlets were like $9 or $10 each on amazon.
The 4 port gettup was about $22 complete. I butchered the wood a little in process so I will need to clean that one up. The 3 under the radio went in no problem. I have them on a switch so I can turn them off if boon docking to save battery and not stare at blue lights all the time. Also wanted a voltage readout for when we boondock. It seems pretty accurate so far compared to my regular tester. Will see how it does after a day on battery.
Now when the kids all forget their plug in chargers- they will still be able to charge and not steal mine. Also gives an option to charge when boondocking and not needing to run the generator or plug into my truck.
If I had to do it over, I would had done the ones by the control panel the same as by the radio. It would had come out a lot cleaner. I got a couple extra. May throw some in the bunk area. I would like to put one or two in my truck now too.
