milleda31's avatar
milleda31
Aftermarket wheels
Gentlemen,
I have a 2016 Ford F350 Lariat LB DRW and a 2008 Lance Max981 camper.
Suspension and current wheels and tires are all stock (Alcoa wheels). I want to switch out the wheels and tires for some aftermarket 20" Fuel's or Vision's. The ones I like require no spacers. The Fuel's are rated at 2500 lbs. and the Vision's are rated at 4300. I would be mounting some Toyo Open Country tires on them.
Clearly the Vision wheels will handle the weight. What do you think about the Fuel's? Also, I sometimes pull a 3500 lbs. boat behind the setup. All my truck gear is Torklift. Camper probably right at about 4000 lbs.
Thoughts? Thanks in advance.
https://www.visionwheel.com/wheel/7210/VisionHDTruck/Trailer/401%20Rival?finishID=591
http://www.fueloffroad.com/wheel/11115/fuel%2Ddually%2Dwheels%2Dtriton%2Ddually%2Drear/?finishID=329&lugs=8
